Voici quelques prises de ce mois d'avril...
Matériel: camera qhy5l II couleur au foyer d'un newton 150/750 heq5, barlow kepler 2.5x
Logiciels: Autostakkert, firecapture, registax, iris
Tout d'abord la lune:
lune%2018.04.16.bmp?dl=1
Acquisition: 1000 frames retenues
Camera=QHY5LII
Filter=RGB
Profile=Moon
Frames captured=5149
File type=AVI
Binning=no
ROI=640x480
ROI(Offset)=0x0
FPS (avg.)=72
Shutter=1.139ms
Gain=237
HDR=on
WRed=85
Contrast=-1
USBTraffic=23
SoftwareGain=10 (off)
WBlue=160
Brightness=1
HighSpeed=on
WGreen=50
Gamma=95
Histogramm(min)=10
Histogramm(max)=211
Histogramm=82%
Moon_223429_g6_ap49.bmp?dl=1
Acquisition: 2000 frames retenues
Camera=QHY5LII
Filter=RGB
Profile=Moon
Duration=60.292s
Frames captured=4301
File type=AVI
Extended AVI mode=true
Compressed AVI=false
Binning=no
ROI=640x480
ROI(Offset)=0x0
FPS (avg.)=71
Shutter=1.139ms
Gain=237
HDR=on
WRed=85
Contrast=-1
USBTraffic=23
WBlue=160
Brightness=1
HighSpeed=on
WGreen=50
Gamma=95
Histogramm(min)=8
Histogramm(max)=210
Histogramm=82%
lune1%2018.04.16.bmp?dl=1
Camera=QHY5LII
Filter=RGB
Profile=Moon
Filename=Moon_223856.avi
Date=180416
Duration=63.313s
Frames captured=4558
File type=AVI
Binning=no
ROI=640x480
ROI(Offset)=0x0
FPS (avg.)=71
Shutter=1.000ms
Gain=232
HDR=on
WRed=85
Contrast=-1
USBTraffic=23
WBlue=160
Brightness=1
HighSpeed=on
WGreen=50
Gamma=95
Histogramm(min)=9
Histogramm(max)=243
Histogramm=95%
Ensuite jupiter (merci astrofildu76 pour les conseils!:)
Jup_230456_g6_ap34_Drizzle15.bmp?dl=1
Camera=QHY5LII
Filter=RGB
Profile=Jupiter
Diameter=42.90"
Magnitude=-2.38
CMI=271.4° CMII=259.8° CMIII=284.9° (during mid of capture)
FocalLength=1700mm
Resolution=0.45"
Duration=93.235s
Frames captured=12737
File type=SER
Binning=no
ROI=320x240
ROI(Offset)=758x136
FPS (avg.)=136
Shutter=10.19ms
Gain=443
HDR=on
WRed=94
WBlue=152
Brightness=6 (off)
HighSpeed=on
Gamma=100 (off)
USBTraffic=23
WGreen=50
Contrast=1 (off)
Histogramm(min)=6
Histogramm(max)=169
Histogramm=66%
ju7000%20iris.bmp?dl=1
Acquisition: 7000 frames retenues
Camera=QHY5LII
Filter=RGB
Profile=Jupiter
Diameter=42.06"
Magnitude=-2.33
CMI=222.7° CMII=142.7° CMIII=170.2° (during mid of capture)
FocalLength=1600mm
Resolution=0.49"
Filename=Jup_221534.ser
Date=180416
Duration=120.871s
Frames captured=14344
File type=SER
Binning=no
ROI=320x240
ROI(Offset)=758x136
FPS (avg.)=118
Shutter=12.74ms
Gain=325
HDR=on
WRed=115
Contrast=1 (off)
USBTraffic=23
WBlue=160
Brightness=6 (off)
HighSpeed=on
WGreen=50
Gamma=100 (off)
Histogramm(min)=7
Histogramm(max)=200
Histogramm=78%
ju2000drizzle%2018.04.16.bmp?dl=1
Camera=QHY5LII
Filter=RGB
Profile=Jupiter
Diameter=42.06"
Magnitude=-2.33
CMI=219.0° CMII=139.1° CMIII=166.6° (during mid of capture)
FocalLength=1600mm
Resolution=0.49"
Filename=Jup_220945.ser
Date=180416
Duration=91.519s
Frames captured=10873
File type=SER
Binning=no
ROI=320x240
ROI(Offset)=758x136
FPS (avg.)=118
Shutter=12.74ms
Gain=325
HDR=on
WRed=115
Contrast=1 (off)
USBTraffic=23
WBlue=160
Brightness=6 (off)
HighSpeed=on
WGreen=50
Gamma=100 (off)
Histogramm(min)=8
Histogramm(max)=200
Histogramm=78%
Et pour finir 2 petites animations (une première pour moi..)
1gifinter4.gif?dl=1
Résultat de 11 ser
gif%2016.04.16.gif?dl=1
Résultat de 48 ser
Bonne soirée à tous et toutes!:)
Modifié par Triff
