ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 bon ,je crois que c'est pire ou j'ai fais faux /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:226:0: warning: "TOTAL_ANALOG_PINS" redefined #define TOTAL_ANALOG_PINS 11 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:185: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:150:0: note: this is the location of the previous definition #define TOTAL_ANALOG_PINS 8 /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:227:0: warning: "TOTAL_PINS" redefined #define TOTAL_PINS 25 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:185: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:151:0: note: this is the location of the previous definition #define TOTAL_PINS 22 // 14 digital + 8 analog In file included from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:189:0: /home/christophe/Arduino/libraries/Adafruit_MLX90614_Library/Adafruit_MLX90614.h:50:7: error: redefinition of 'class Adafruit_MLX90614' class Adafruit_MLX90614 { ^~~~~~~~~~~~~~~~~ In file included from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:5:0: /home/christophe/Arduino/libraries/Adafruit_MLX90614_Library/Adafruit_MLX90614.h:50:7: note: previous definition of 'class Adafruit_MLX90614' class Adafruit_MLX90614 { ^~~~~~~~~~~~~~~~~ Plusieurs bibliothèque trouvées pour "Firmata.h" Utilisé : /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata Non utilisé : /home/christophe/Arduino/libraries/arduino-master Plusieurs bibliothèque trouvées pour "Adafruit_TSL2591.h" Utilisé : /home/christophe/Arduino/libraries/Adafruit_TSL2591_Library Non utilisé : /home/christophe/Arduino/libraries/Adafruit_TSL2591_Library-master exit status 1 Erreur de compilation pour la carte Arduino Nano je dois enlever les autres et mettre que celles que tu m'as donné
ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 et se message en mettant que t'on fichier /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:226:0: warning: "TOTAL_ANALOG_PINS" redefined #define TOTAL_ANALOG_PINS 11 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:185: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:150:0: note: this is the location of the previous definition #define TOTAL_ANALOG_PINS 8 /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:227:0: warning: "TOTAL_PINS" redefined #define TOTAL_PINS 25 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:185: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:151:0: note: this is the location of the previous definition #define TOTAL_PINS 22 // 14 digital + 8 analog In file included from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:189:0: /home/christophe/Arduino/libraries/Adafruit_MLX90614_Library/Adafruit_MLX90614.h:50:7: error: redefinition of 'class Adafruit_MLX90614' class Adafruit_MLX90614 { ^~~~~~~~~~~~~~~~~ In file included from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:5:0: /home/christophe/Arduino/libraries/Adafruit_MLX90614_Library/Adafruit_MLX90614.h:50:7: note: previous definition of 'class Adafruit_MLX90614' class Adafruit_MLX90614 { ^~~~~~~~~~~~~~~~~ exit status 1 Erreur de compilation pour la carte Arduino Nano visiblement il n'y a que cela qui pose problème ,non ? In file included from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:189:0: /home/christophe/Arduino/libraries/Adafruit_MLX90614_Library/Adafruit_MLX90614.h:50:7: error: redefinition of 'class Adafruit_MLX90614' class Adafruit_MLX90614 { ^~~~~~~~~~~~~~~~~ In file included from /home/christophe/Téléchargements/indiduinoMETEO/indiduinoMETEO.ino:5:0: /home/christophe/Arduino/libraries/Adafruit_MLX90614_Library/Adafruit_MLX90614.h:50:7: note: previous definition of 'class Adafruit_MLX90614' class Adafruit_MLX90614 { ^~~~~~~~~~~~~~~~~ exit status 1 Erreur de compilation pour la carte Arduino Nano
olivier1986 Posté 13 mai 2020 Posté 13 mai 2020 ok, on reprend tu fermes ton IDE arduino. dans ton répertoire librairie, tu crées un répertoire old. tu mets toutes les librairies pésentes dans le dossier old. tu mets tout ce qu'il y dans le dossier librairie nécessaires.zip dans le dossier librairie devenu vide. tu dois donc avoir un dossier librairie avec mes librairies fournies et un dossier old avec les tiennes dedans. Ensuite ouvres le skech que je te joins également (j'ai mis tes capteurs MLX90614, BME280 et TSL). ensuite tu compiles et redis moi. libraries necessaires.zip indiduinoMETEO.ino
ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 alors j'ai juste copier les fichiers et mis les autres dans un fichier OLD Mais du coup j'ai ça /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:220:0: warning: "TOTAL_ANALOG_PINS" redefined #define TOTAL_ANALOG_PINS 11 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:179: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:150:0: note: this is the location of the previous definition #define TOTAL_ANALOG_PINS 8 /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:221:0: warning: "TOTAL_PINS" redefined #define TOTAL_PINS 25 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:179: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:151:0: note: this is the location of the previous definition #define TOTAL_PINS 22 // 14 digital + 8 analog Le croquis utilise 21728 octets (70%) de l'espace de stockage de programmes. Le maximum est de 30720 octets. Les variables globales utilisent 1223 octets (59%) de mémoire dynamique, ce qui laisse 825 octets pour les variables locales. Le maximum est de 2048 octets. Bibliothèque non valide trouvée dans /home/christophe/Arduino/libraries/Old : aucun fichier d'en-tête (.h) trouvé dans /home/christophe/Arduino/libraries/Old Bibliothèque non valide trouvée dans /home/christophe/Arduino/libraries/Old : aucun fichier d'en-tête (.h) trouvé dans /home/christophe/Arduino/libraries/Old Mais ça quand même passer on dirais
olivier1986 Posté 13 mai 2020 Posté 13 mai 2020 etonnant, normalement les lignes sont bien celle là: #define TOTAL_ANALOG_PINS 11 #define TOTAL_PINS 25 je ne sais pas d'ou il sort le 8 !! as tu la dernière version de firmata à tout hasard?
ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 alors je sais pas ,comment je trouve la version ? est-ce que cela peut venir que je suis sur une nano ?
ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 (modifié) le capteur TSL2591 remplace le système IRRADIANCE_SENSOR ? Modifié 13 mai 2020 par ch_porchet
olivier1986 Posté 13 mai 2020 Posté 13 mai 2020 il y a 2 minutes, ch_porchet a dit : est-ce que cela peut venir que je suis sur une nano ? Non j'ai essayé et le code passe bien sans erreurs. Pour firmata il faut aller dans l'IDE puis: - outils - gérer les bibliothèques - taper firmata dans la barre de recherche - la 1ere doit être écrit version 2.5.8 installed si ce n'est pas le cas il faut l'installer puis fermer l'IDE et relancer le sketck pour recompiler
ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 non alors j'ai bien la bonne version. tu choisi Arduino meteoStation dans kstars , moi j'ai essayé ,mais elle se déconnecte. bon j'ai toujours rien branché dessus pour l'instant
olivier1986 Posté 13 mai 2020 Posté 13 mai 2020 si les capteurs ne sont pas branché pour lancer avec kstars ca ne fonctionne pas. egalement bien vérifier dans l'onglet connexion que tu as le bon bon "baud rates" à 57600 vérifier aussi que c'est le bon port: pour moi il est sur ttyACM0 et non pas un USB... il y a 3 minutes, ch_porchet a dit : tu choisi Arduino meteoStation dans kstars , moi j'ai essayé ,mais elle se déconnecte. oui
ch_porchet Posté 13 mai 2020 Auteur Posté 13 mai 2020 bon je vais aller me coucher j'ai pas trouvé les pin de connexion des capteurs je verrais demains A+ et merci
olivier1986 Posté 13 mai 2020 Posté 13 mai 2020 Pas de soucis! pour info: BME + MLX sont branché sur les ports A4 et A5 ( qui correspondent à SDA et SCL) de la carte. pour le BME je sais pas mais pour mon MLX c’était soudé sur une carte avec les scriptions VCC GND SDA et SCL du coup facile! SDA sur le port A4 et SCL sur le port A5. le capteur de luminosité est branché sur A0 bonne nuit!
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 alors j'ai fais un test avec MLX , ben kstars me met des valeurs impossible! cloud =100% ,bon c'est possible je suis dans mon salon skytemp =218.3 !!
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 (modifié) Avec le mlx tu dois avoir 2 valeurs: la valeur de la température ambiante et celle du ciel. la valeur que tu donnes doit être celle de l’ambiante. et il se peut qu’il y est un facteur 10. dans le code mois la valeur était de 0.2 car les 2 températures du mlx dans le code étaient divisé par 100. dans ce cas dans le code tu as juste a divisé par 10! A près faut être sur que chez toi tu es bien les 21 degrés edit: chez moi en salon la valeur est de 21 degres et le ciel est de 13 degres! Donc couvert car dans le code le ciel est dégagé a partir de -8 degres! Modifié 14 mai 2020 par olivier1986
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 OK je vais aller contrôler sa dans 15min. Par contre l'autre capteur ne donne rien, celui de la pression. Y a un moyen de contrôler le fonctionnement sans kstars ?
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 ok mais je pense que ça marche pas , car si je met mon doigt dessus rien ne change , mais si je le débranche. Il y a un moyen de lire les valeurs que reçois l'arduino ,mais sans kstars ?
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 Oui, il faut mettre le sketch meteotest en prenant soin de désactiver les capteurs inutules. une fois televersé tu ouvres le moniteur serie de l’IDE, tu choisis la bonne. Vitese et tu auras les valeurs des capteurs. je peux te fournir le fichier pour ta config. moi le mien ne contient que le mlx!
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 alors je veux bien essayer , mais que veux-tu dire par le sketch ? dis moi tu as aussi ces message quand tu compiles /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:220:0: warning: "TOTAL_ANALOG_PINS" redefined #define TOTAL_ANALOG_PINS 11 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:179: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:147:0: note: this is the location of the previous definition #define TOTAL_ANALOG_PINS 6 /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:221:0: warning: "TOTAL_PINS" redefined #define TOTAL_PINS 25 In file included from /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Firmata.h:17:0, from /home/christophe/Téléchargements/indiduinoMETEO1/indiduinoMETEO1.ino:179: /home/christophe/Téléchargements/arduino-1.8.11/libraries/Firmata/Boards.h:148:0: note: this is the location of the previous definition #define TOTAL_PINS 20 // 14 digital + 6 analog
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 alors fut un moment ou effectivement j'ai eu une erreur sur les pins. je ne sais pas comment mais elles n'y sont plus. Je pense plus à une erreur liée à une librairie. Mais comme tu compiles les skecth sur linux et moi sur windows je ne sais pas trop! c'est pour cela que je t'ai fourni hier l'ensemble des librairies nécessaires, mais il en manque peut être une. le sketch est le programme que tu téléverse dans l'arduino. Peux tu me dire les capteurs que tu utilisent pour tester stp?
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 Ok Alors le BMP280 le MLX90614 et je voudrais comparer les valeur entre le BMP et le DHT22 , mais ça c'est une option
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 Pour tester le mlx dans l'IDE je te mets le fichier de test à compliler. Je te joins aussi la librairie dht (tu en a une autre DHT qui est du coup en majuscule mais il te faut les 2!! la case est très importante). vitesse de communication = 9600 dis moi si cela fonctionne. METEOtest.ino dht.zip
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 voilà kle fichier test pour tes 3 capteurs METEOtest_DHT22_BME280_MLX90614.ino
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 (modifié) alors j'ai essayer et regarder dans le moniteur série , j'ai pas de valeurs ? 23:29:13.924 -> IR read, start 23:29:13.957 -> IR read, done 23:29:13.957 -> DHT read, start 23:29:13.990 -> Time out error 23:29:13.990 -> Could not read DHT11 (HR) sensor, check wiring! 23:29:14.057 -> DHT read, done 23:29:14.057 -> BMP read, start 23:29:14.090 -> Could not find a valid BMP085 / BMP180 (P) sensor, check wiring! 23:29:14.157 -> IR Radiance sensor skipped, not defined!. 23:29:14.223 -> RESULT 23:29:14.223 -> IR:1037.55, P:0.00HR:0.00, DEW:nan, IR Radiance:0.00, Temp HR:0.00, Temp IR:1037.55, Temp P:0.00 23:29:14.322 -> 23:29:14.322 -> je me demande si ils sont bien connecter ? Au faite , quand j'installe le code ,je n'est aucune erreur ou message Modifié 14 mai 2020 par ch_porchet
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 Bon , j'avance ,j'ai mondifier dans le code qqch . C'était mis BMP085 et j'ai mis BMP280 et j'ai des valeurs . mais toujours pas de bonne valeur pour IR
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 Déjà s'il n'y a pas d'erreur c'est pas mal!! pour le BMP je ne sais je vais voir, mais pour le MLX dans IR tu devrais avoir une valeur plus proche des 20) !! ton MLX est il vendu sous cette forme ci: https://fr.aliexpress.com/item/32860955758.html?src=google&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Gploogle_7_shopping&aff_atform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=6459788344&albag=76234907246&trgt=743612850874&crea=fr32860955758&netw=u&device=c&albpg=743612850874&albpd=fr32860955758&gclid=Cj0KCQjw2PP1BRCiARIsAEqv-pQQZb-z-sCuo8TNnttMtxOyD2GF5iSjPingyLguvMz3aIVYY3KIu7waAr_MEALw_wcB&gclsrc=aw.ds je veux dire avec un pcb En effet il y avait 2 lignes à modifier, autant pour moi
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 Non ,j'ai pas celui ci https://www.distrelec.ch/fr/mlx90614-ncir-remote-infrared-temperature-sensor-unit-m5stack-u028/p/30172531 il y a un bout de code dans le fichier d'explication
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 (modifié) #include <M5Stack.h> #include <Wire.h> #define NCIR_ADDR 0x5A // declaration uint16_t result; float temperature; // initialization Wire.begin();\ M5.begin(); // read data Wire.beginTransmission(NCIR_ADDR);Wire.write(0x07);Wire.endTransmission(false); Wire.requestFrom(NCIR_ADDR, 2); result = Wire.read();// Receive DATA result |= Wire.read() << 8;// Receive DATA // store temperature value temperature = result * 0.02 - 273.15; Voila l'extrait de code mis en exemple Modifié 14 mai 2020 par ch_porchet
olivier1986 Posté 14 mai 2020 Posté 14 mai 2020 Oui effectivement va falloir reprendre le code!! je peux essayer de regarder cela si tu veux
ch_porchet Posté 14 mai 2020 Auteur Posté 14 mai 2020 Ouai cela serai cool, moi je sais faire que des chose simple, comme pour le toit. Mais je vais aussi essayer de mon côté, et je verrai la différence avec le tiens.
