Bonjour a tous
Je cherche une caméra oculaire USB compatible Android d'entrée de gamme.
En effet les modèles existants sont généralement conçus pour PC, mais il est plus facile de transporter une tablette qu'un PC, d'où ma question.
Des avis ?
Merci pour vos futur réponses.
Raphaël
Bonsoir ,
Stp , j.ai trouvé celà sur ali : trois produits ....
https://fr.aliexpress.com/item/32846840086.html?spm=a2g0o.detail.1000014.10.783759cfdxw3FM&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.158757.0&scm_id=1007.14976.158757.0&scm-url=1007.14976.158757.0&pvid=b0fc9bdc-6a2e-492f-8f87-bcbb62be98fb&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.14976.158757.0,pvid:b0fc9bdc-6a2e-492f-8f87-bcbb62be98fb,tpp_buckets:668%230%23131923%2316_668%23808%235965%23470_668%23888%233325%239_4976%230%23158757%230_4976%232711%237538%23795_668%232846%238116%23944_668%232717%237561%23337
https://fr.aliexpress.com/item/4000483214295.html?spm=a2g0o.detail.1000014.8.236a71fbArvekH&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.158757.0&scm_id=1007.14976.158757.0&scm-url=1007.14976.158757.0&pvid=d265d924-e6d7-4e24-8c75-7754be11a7a9&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.14976.158757.0,pvid:d265d924-e6d7-4e24-8c75-7754be11a7a9,tpp_buckets:668%230%23131923%2313_668%23808%235965%23470_668%23888%233325%239_4976%230%23158757%230_4976%232711%237538%23795_668%232846%238116%23944_668%232717%237561%23337
https://fr.aliexpress.com/item/32962849850.html?spm=a2g0o.detail.1000014.32.379c159bLuKUWf&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.158757.0&scm_id=1007.14976.158757.0&scm-url=1007.14976.158757.0&pvid=a7cf1c69-673c-4317-9a11-369e092216ed&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.14976.158757.0,pvid:a7cf1c69-673c-4317-9a11-369e092216ed,tpp_buckets:668%230%23131923%2316_668%23808%235965%23470_668%23888%233325%239_4976%230%23158757%230_4976%232711%237538%23795_668%232846%238116%23944_668%232717%237561%23337
tiens nous informé en retour,
stp...
bien à toi,
 cordialement ,
w ;-).
Modifié par kikiwillybee
Ah merci je vais voir la chose :)  Ali est il un site à problème ou assez fiable? merci
 Bonjour Raphi ... ! 😉 ..
Yess ! Fiable    Je l.utilise régulièrement, à part les délais de l’ordre de. Trois semaines mini en ce moment ..comme EBay ton article est assuré , remboursé en cas de non acheminement..
verifies stp , le même article peut être proposé par plusieurs vendeurs, avec des différences de prix ...
bien à toi ,
 cordialement
w 😉 .
  • 4 semaines plus tard...
Re bonjour a tous, tout d'abord encore une fois merci à kikiwillybee pour la réponse et dès idées de recherche.
Voila, je me suis finalement dirigé vers la "Celestron digital caméra" de 2MP
Contenu de la boîte:
- La caméra oculaire de 2MP au diamètre de 23.5mm (YES! compatible microscope et SURTOUT vieux instruments au coulant Japonais!)
- Adaptateur coulant microscope 30mm (donc facilement adaptable sur 31.75mm de 1.25)
- cd drivers et logiciels
- câble mini USB
 Compatible xp, vista, seven, win8 et bien sur win10, j'ai personnellement testé sous win10 et pas besoin du logiciel celestron, la caméra est automatiquement compatible avec l'appli "Caméra" de win10.
Mais la bonne nouvelle, car pas prévu à la base, la caméra est compatible Android! (YES!), a condition d'avoir un smartphone compatible "OTG" (testé sous Android 6), un câble USB OTG et l'appli gratuite "CaméraFi".
J'ai pas testé sur IPhone.
Pour finir, des photos de la bête! 🤩
