Hi,Ola,Bonjour,...
nugz
J'ai extrait de ce lien http://www.televue.com/engine/page.asp?ID=311 le passage ci après, où je vois pour la première fois mention de la combinaison du facteur de contratse avec le facteur de grossissement, et le lien avec le champ... Peut être une piste d'explication aux raisons qui font trouver les images à grand champs si séduisantes ?...
Considering the potential of Ethos, let me posit a more general conclusion:
For deep sky viewing of star fields, open and globular clusters, nebulae and galaxies, choose the highest power that frames the subject, so long as the sky background does not reach black, and the atmosphere does not degrade the resolution. The smaller exit pupils permit a darker sky background which achieves greater contrast against the fixed brightness of stars, while the greater magnification reveals more structural details on extended objects. Using eyepieces with larger apparent fields increases the magnification potential. The result is an increase in what I would call the Majesty Factor, the nexus of contrast, power and field.
It's clear that the largest possible apparent field for a given true field yields the most magnification for greater resolution, with a darker sky background for more contrast as a result of the smaller exit pupil. I believe this combination of contrast, power and field causes the typical "wow" reaction the Majesty Factor. I think Tom Trusock said it most succinctly in his Starfest (Canada) report: "The same true field at higher magnification means that you'll see blacker skies and more detail." Dennis di Cicco in his 5-star review of Ethos in his October 2007 Sky & Telescope review noted something similar: "Observing with the 12-inch scope, I typically bounce between a wide-field eyepiece for star-hopping and a high-power one for detailed views. But the Ethos gave me both. The field was large enough to star-hop, and the magnification was high enough to bring out faint stars and resolve details in galaxies and star clusters." (He coincidently also illustrated field sizes using the Double Cluster.)
Let's try to quantify the so-called Majesty Factor. While we cannot quantify the majesty of a great symphony, work of art or edifice, I think a meaningful Majesty Factor is quantifiable for those great deep sky views. Here's how:
For Reference
Basic Telescope and Eyepiece Concepts
  • apparent field: perceived span of sky seen through eyepiece (without telescope). Not used in true field (see) calculation.
  • exit pupil: image of objective formed by eyepiece. Location where full apparent field is seen.
  • f/#: a ratio that describes the relation between the aperture and focal length of the telescope -- important for photography
  • field stop: ring inside the eyepiece barrel that limits true and apparent field size
  • focal length: effective distance from entrance of an optical system to focal point
  • magnification: relative change in angular size of object
  • true field: span of sky seen through telescope/eyepiece combination
Basic Telescope and Eyepiece Formulas
Let's consider a range of possible eyepieces with apparent fields of 50°, 60°, 68°, 82° and 100°. Now let's pick an object, (like the Double Cluster) and let's say it's properly framed in the field of a 50° Plössl with a 26-mm focal length in an f/10 telescope so the exit pupil = 2.6-mm. Let's arbitrarily assign a factor of 1 to the power (magnification) of this telescope and a factor of 1 to represent the contrast for the 2.6-mm exit pupil. Therefore, for the given true field, the Majesty Factor = 1 (power factor) x 1 (contrast factor) = 1.
Now let's replace the Plössl with a 100° (apparent field) Ethos with a 13-mm focal length. This yields the same true field of view at twice the power with twice the apparent field and half the exit pupil. The 1.3-mm exit pupil is only ¼ the area of 2.6-mm, so the sky background darkens by a factor of 4 (contrast factor). The magnification power factor yields twice the detail or resolution. Therefore: 2 (power factor) x 4 (contrast factor) = 8x Majesty Factor
Working out the math for all the apparent fields listed above, we have:
Majesty Factor for Various Apparent Fields
for Eyepieces Yielding Same True Field
Apparent Field (°)Power Factor Contrast Factor Majesty FactorPlössl501.00x1.00=1.00Radian601.20x1.44=1.73Panoptic681.36x1.85=2.52Nagler821.64x2.69=4.41Ethos1002.00x4.00=8.00
Is this a fair representation for quantifying the Majesty Factor? I'd very much like to hear your opinions, preferably after you have actually viewed through the Ethos.
Bonjour à toutes et tous,
Je m'appelle Olivier, j'habite en Belgique, j'ai 24ans. L'astronomie et l'astrophysique sont des passions parmis tant d'autres...
Merci à toute la team du site, super complet et tout et tout!
J'espère y contribuer...Tiens ben je vais commencer! ;)
Bienvenue Nugz !
Quel coin de Belgique ? Quel matos ?
Liège, le matos prochainement! ;)
Salut et bienvenue à bord, Olivier ... :)
Bon, ça fait un moment qu'on a dit "Plus de belges ici", mais j'vois qu'il n'y a rien à faire, vous débarquez en force !!! Il ne nous reste plus qu'à nous effacer devant cette invasion !!! :be:
Bah de toute façon, un jour où l'autre, la Wallonie sera rattachée à la France :be: (humour Belge pas drôle mais qui marche bien sur la RTBF)
Certes...je ne suis pas allé jusqu'au bout car j'ai bloqué sur une formule que moi y en a pas comprendre:
true field = eyepiece field stop x 57.3° / telescope focal length
Une idée d'où vient cette formule magique?
c'est la formule de la tangente (dans un triangle rectangle, tan alpha = côté opposé divisé par côté adjacent : dans le cas présent le côté opposé c'est le diamètre du diaphragme de champ et le côté adjacent c'est la focale). Dans cette formule on peut confondre un angle (exprimé en radians) et sa tangente, dès lors que l'angle est petit. Le coeff 57,3 est là pour convertir des radians en degrés (57,3 c'est 180° divisé par pi).
En photo on a la même formule pour calculer le champ : 57,3 * taille capteur / focale (ces deux données dans la même unité, en mm par exemple).
Ma question est donc de savoir si je vois aussi bien ces objets avec mon scope que si j'avais un scope a grand champ ? :?:
Selon ma compréhension, oui.
La comparaison ci-avant porte sur la différence entre oculaires de champs apparents différents, à grossissement donné.
Mais bon, je n'ai pas forcèment tout compris des finesses du rapport F/d.
Champ réel = champ apparent/grossissement = champ apparent . f/F
A partir de la fiche jointe en pdf:
champ de l'oculaire (champ apparent) = 360. field stop/ 2.pi.f
et
champ réel = (360. field stop/ 2.pi.f). f/F = 57,3. field stop/ F
PS: grillé par tout le monde :cry:
Bonjour Olivier, le Liégeois, :)
Bienvenue sur le forum Webastro. :be:
Peux-tu nous faire savoir quel a été l'événement qui est à l'origine de ta passion pour l'astronomie (sans doute à la fin des années nonante ?...) : éclipse, comète, mission spatiale, ou autre événement ?... :?:
Roger la Cantalien. :rolleyes:
Oui oui je sais tout ça mais ma question portait plutot sur le contraste et la luminosité.
Normalement mon scope a f/d 11.5 est aussi lumineux qu'un scope a f/d 5 pour le même diametre donc a part le champ pourquoi serait il moins adapté au ciel profond ?
Hervé
à grossissement identique, la pupille de sortie ne dépend que du diamètre de l'instrument, le F/D n'intervient pas (si ce n'est qu'obtenir un grossissement faible avec un F/D élevé n'est pas toujours facile).
Le F/D intervient en photo :
en écrivant les choses différemment, si on cherche un grandissement identique avec deux instruments alors ils devront avoir la même focale. Celui qui a le plus gros diamètre sortira plus de lumière sur le plan du film, ce qui réduira le temps de pose. Mais celui qui a le plus gros diamètre aura évidemment le F/D le plus faible puisque la focale des deux instruments est identique. Peut-être que c'est plus intuitif exprimé comme ça :?:
Hervé,
C'est à Patte que je répondais, d'où le flou... Tu disais :
Mon scope a une focale de 2415 pour 210 de diametre.
On me dit qu'il n'est pas adapté au ciel profond car limité justement en champ... Ma question est donc de savoir si je vois aussi bien ces objets avec mon scope que si j'avais un scope a grand champ ?
Hervé
Avec 2450mm de focale, ton champ maximum possible, quel que soit l'oculaire, est de 0,75° en 31,7mm.
Donc il va tronquer les grandes formations du ciel profond: M42, les Dentelles etc...
Si tu avais un Tuyau de plus courte focale, en 31,7mm toujours, tu aurais un champ plus grand.
C'est donc une question de goût, de choix personnel: si tu aimes le grand champ, c'est pas vraiment le bon Tuyau!
A part cela, il est aussi "adapté" au ciel profond qu'un Tuyau plus court...
je suppose que c'est un Mewlon ou autre variante de Cassegrain? Alors tu peux mettre un réducteur de focale, ou passer en 50,8mm, tu vas gagner du champ, mais combien je ne sais pas, cela du tube baffle interne. Il faudrait mesurer sur le ciel...
PS: je t'invite à lire les fiches "Principes de l'optique" en tête de ce forum!
A part le champ, ton scope est équivalent à tout autre scope de diamètre équivalent pour le ciel profond (en visuel). A grossissement égal, la luminosité est la même. Et le champ réel itou (celui-ci étant une fonction du champ apparent de l'oculaire et du grossissment).
La suggérée "moins bonne adaptation au CP" provient du fait que, la focale étant plus élevée, pour avoir un grossissement pas trop élevé, il te faudra des oculaires de focales extrêmement élevée.
C'est ça ?
ah desolé pour toi mais on n accepte plus les Belges:be: Parait qu il y en a de trop sur le forum , comme nous les Bretons, meuh bon faut faire avec:be:
en tout cas bienvenue a toi sur le forum;)
:drapobe::drapobe::drapobe: Salut notre Litcheu ami t'es vraiment binamé par ici :be:
Nan nan Hervé, on n'arretera pas l'invasion ;) Et en plus quand on d&barquera dans les starparties, on vous obligera à boire de la bière (Chimay, Duvel, Rochefort Hmmmmm ... ):be::be::be:
Newton : ben oui le jour ou les flamands accepteront de se rallier à la Hollande :laughing-smiley-012:laughing-smiley-012:laughing-smiley-012c'est pas demain la veille :be:;)
Hihihi, c'est vrai que ça vire au match belgo-breton ce forum :be: (je trouvais que bretonno-belge ça ne sonnait pas bien ;))
Hervé,
Merci, c'est bien ce que je pensais mais je voulais avoir confirmation. :)
Et comme c'etait la premiere fois cette été que je pouvais observer des galaxies et nebuleuses (et oui elles sont invisible de chez moi en rp), j'ai vu que je pouvais observer un grand nombre d'objets du ciel profond sans probleme de champ donc j'ai été agreablement surpris.
Par contre la vision des galaxies m'a un peu déçu car je pensais les voir avec plus de contraste.
ps Oui c'est bien un Mewlon.
Hervé
C'est ça ?
Le champ maxi pour ce scope est de 1,2° avec reducteur ce qui est déjà pas mal.
En tout cas merci pour la reponse dont j'etais quasiment sur egalement mais comme j'entendais plein de gens me dire que mon scope n'etait pas adapté au ciel profond j'ai eu tout a coup comme un doute et je me suis posé la question de savoir si a part le champ il y avait autre chose, mais non donc je suis ravi. :)
Hervé
J'ai pas trop compris comment on obtient un meilleur contraste sur les objets diffus (nébuleuses, galaxies...) en grossissant plus? Parce qu'en grossissant 2x plus, le fond du ciel est 4 fois plus sombre, mais l'objet contemplé aussi...
Ou alors est-ce à cause du seuil minimal pour lequel l'oeil humain détecte quelque chose?
L'été chez nous le ciel est clair, nous sommes déjà très au Nord... Dès septembre, attends une belle nuit transparente et sans Lune, et là tu verras de quoi est capable ton Tuyau, ton magnifique Tuyau!
Et j'te parle pas des mois d'hiver, là c'est la fête du ciel profond! Ciel noir, noir comme ton âââââme!
En ce moment, le ciel noir commence seulement à revenir, entre minuit et trois heures du matin...
Le probleme c'est que quand le ciel est noir je suis en rp et au moment où je suis sous des cieux meilleurs ( en general en vacances en été) la nuit est clair. :mad:
Bon enfin tout n'est quand même pas noir (enfin question de parler :be:) car je trouve que les planetes et les amas sont tout de même superbe même en region parisienne.
Hervé
Bruno a une théorie là-dessus, je ne sais plus laquelle... il va bien passer par là!
Perso je constate qu'en grossissant, le fond de ciel noircit plus vite que les sujets observés. Alors tout dépend du sujet en question. ça marche très bien avec des sujets très lumineux, comme l'anneau de la Lyre, l'Oeil de Chat, la nébuleuse Saturne.... et beaucoup moins, voire pas du tout avec des sujets de grandes dimensions, comme Hélix.
En fait, plus la luminosité surfacique est élevée, mieux ça marche...
CAL: Je suis plus brrruxellois que liègeois manneke (les belches comprendront!;)).
Newton: Pour ce qui est de la division de la Belgique, c'est pas encore pour demain, bien qu'ils m'ont fait peur nos politicons cette année!
roger15: En ce qui concerne ma révélation pour l'astronomie, elle est pas très orginale, c'est en feuilletant un guide d'astronomie qu'un poto m'avait prêté, que je me suis dis c'est vraiment pas mal...tient pourquoi pas regarder avec des jumelles...et ainsi de suite... :D
Pour clôturer, vive les frrrites et la Leffe blonde!:D
ce n'est pas la peine de chercher à mettre ça en équations.
Ben oui peut-être, mais ce n'est pas qu'il y a recherche de "mettre en équations", les équations sont là, quelque part, et seront découvertes un jour ou l'autre. ;)
