Merci pour ces liens très intéressants.
Même si les nouvelles ne sont pas bonnes Concernant Spirit, au vu de leurs prolongations inattendues, cela restera un franc succès.
Phil.
Bonsoir à tous,
Salut Phil,
Ce soir un petit coup d'oeil au blog "Free Spirit" de la NASA et aux dernières nouvelles des tests menés en vue de sortir le rover de son bourbier martien :
Tests on Earth simulating Spirit's predicament on Mars have reinforced understanding that getting Spirit to rove again will be very difficult.
To supplement the tests at NASA's Jet Propulsion Laboratory in Pasadena, Calif., the rover team is refining a detailed computer model of rover mobility, calibrated with results from testing and measurements from Mars.
"The computer modeling will allow us to connect the results from tests performed in Earth gravity with what to expect from the rover in Mars gravity," said JPL's John Callas, project manager for Spirit and its twin, Opportunity.
Spirit became embedded in soft soil at a site called "Troy" in early May, more than five years into a mission on Mars that was originally scheduled to last for three months. The rover team suspended further driving attempts with Spirit while evaluating possibilities from tests performed at JPL simulating the Troy situation.
An additional round of testing was added to the September schedule to gain more detailed assessment of how to move Spirit while avoiding putting the rover's center of gravity directly over a rock that is touching or nearly touching the rover's underbelly. Other added tests are using a lighter-weight test rover than the one used for most of the testing this summer. A complete "dress rehearsal" test of the extrication strategy judged to hold the best chance of success is planned in the test setup at JPL before the team commands Spirit to begin driving. That test and subsequent review of its results are expected to take several weeks. Moves by Spirit will not begin before October, according to current plans.
"We are proceeding very cautiously and exploring all reasonable options," Callas said. "There is a very real possibility that Spirit may not be able to get out, and we want to give Spirit the very best chance."
A dust storm that had reduced the electrical output from Spirit's solar panels by nearly half during late August still has some lingering effects on the skies above Spirit.
On retiendra pour l'essentiel la modélisation informatique visant à une corrélation fine entre les essais sur Terre et les conditions martiennes dans lesquelles évolue Spirit, et surtout l'annonce que les premières manoeuvres du rover n'interviendront pas avant le mois d'octobre.
Et pour ma part, je vais poster des images comme à mon habitude. Celles-ci viennent de Opportunity :).
Alors où qu'il est? Un coup d'oeil sur la carte de Tesheiner d'UMSF
index.php?act=attach&type=post&id=18999
Le rover a passé quelques temps près, et autour de Block Island, la météorite.
Il a effectué -après de nombreuses analyses et vues au microimager- un tour presque complet autour de BI.
Le voici :
Respectivement : Sol 1996, 2000 (2000 Sols, ça se fête!), 2001 (2 images)et 2003.
Ensuite, Oppy est revenue sur ses tours de roue pour aller vers le premier objectif, explorer deux cratères (visibles sur la route map).
Panoramique couleur du Sol 2004
Et du Sol 2006, Navcam :
Tout est mis ici pour avoir des résolutions plus conséquentes.
Petit update basé avec mes propres traitements.
D'abord, rien du côté de Spirit. Ça ne bouge pas trop.
Côté Opportunity, il se déplace, et il bien le bougre. Jugez en plutôt de la carte de trajet :
Deux cartes, une moins récente que l'autre pour bien voir d'où l'on vient :
index.php?act=attach&type=post&id=19062
index.php?act=attach&type=post&id=19087
Sur la route au Sol 2006, il retrouve ses précédentes traces.
Sol 2010, un panorama encore incomplet du cratère Néreus, qui est un peu plus grand que le suivant :
Sol 2011, arrêt près du cratère Nautilus.
Si vous avez des lunettes 3D, c'est par là…
Sol 2015, le tout petit cratère Gjøa (oui vous avez bien lu, je crois que c'est le nom le plus étonnant que j'ai lu pour une formation martienne :p).
Je voudrais vous faire partager ma dernière production qui m'aura donné un peu de fil à retordre.
Le panorama du cratère Néreus au Sol 2010, à la pancam.
Merci Fourmi, :)
J'ai fait en sorte d'avoir cette photo sur tout mon écran.
Drôlement surprenant tous ces détails, c'était comme si on y était, il suffisait de se promener de gauche à droite avec la souris.
Magnifique!
Phil.
Modifié par Phil.
Hé hé, merci Cartouche ;)
Vous vous souvenez de Block Island? Eh bien je vous présente Shelter Island, une nouvelle météorite découverte par Oppy. La voici au Sol 2022, au centre de l'image, on ne peut pas la manquer ;)
J'attends les vues Pancam rapprochées en couleur.
Tenez, de nouvelles images de ma composition (mais ça même plus besoin de le dire) de Shelter Island, au Sol 2024, avec cette fois-ci de la couleur.
Et pour mieux situer le contexte :
Retour au Sol 2010 avec ce panorama du cratère Néreus, en couleurs cette fois-ci :
Je me disais bien qu'ils ne pouvaient pas se limiter qu'à des vues sous filtre L2 et R1 :D.
Update Free Spirit :
http://www.jpl.nasa.gov/news/news.cfm?release=2009-153
C'est le début des tests dits "opérationnels" : les ingénieurs du JPL se mettent en conditions réelles, c'est-à-dire qu'au lieu de regarder sous tous les angles les effets des manœuvres effectuées avec la maquette, ils vont désormais se contenter de données "réalistes", que Spirit sera effectivement capable de fournir (une vue de son ventre avec le micro imager par exemple). Ces tests sont indispensables car il est beaucoup plus difficile de piloter un rover ensablé à des millions de kilomètres de la Terre qu'une maquette qu'on a sous les yeux.
Voilà en tout cas un pas de plus vers une première tentative de "libération" qui n'a cessé d'être repoussée (cinq mois déjà que Spirit est coincé dans les sables de Troie). Continuons à croiser les doigts pour notre vaillant rover !
oui j'ai vu cette info aussi, c'est vrai que c'est embêtant, mais quand on voit qu'il communique depuis 69 mois au lieu des trois prévus, c'est quand même que du bonus depuis. :)
http://www.jpl.nasa.gov/news/news.cfm?release=2009-158
Et puis, ce que l'avenir nous réserve est tout simplement génial : http://www.futura-sciences.com/fr/news/t/astronautique/d/bientot-une-armada-de-robots-pour-explorer-titan_21117/
Astronomicalement
Eh bien voilà, enfin du mouvement du côté de Spirit! En effet, les manoeuvres ont commencé, comme le montrent ces animations du Sol 2078.
Navcam :
Et surtout la caméra arrière :)
index.php?act=attach&type=post&id=19574
Source des images : UMSF
C'est peu, mais c'est déjà ça, surtout avec les énormes précautions qu'à du prendre le JPL pour réaliser ça enfin pour de vrai.
Modifié par Fourmi103
Merci Fourmi pour ces vidéos.
Allez Spirit, on est avec toi !! :wub: Il faut que cette formidable aventure continue.
Effectivement, ça bouge légèrement !
Pour apporter une précision, indirectement selon la même source (UMSF), le rover ne serait pas encore, à proprement parlé, déplacé.
Nous ne constaterions, sur ces images, que les effets de la réorientation des roues dans la bonne direction, avant d'entreprendre les oprérations d'extraction.
C'est cette remise dans l'axe qui a produit ce léger mouvement.
Les grandes manoeuvres devraient commencer incéssamment sous peu.
Quelle amin ! :o On voit parfaitement une des roues bien ensablée, et son mouvement de rotation.
Merci.
Je me tourne du côté d'Opportunity avec cette roche nommée "Marquette Island" (joli nom hein? c'est français! -enfin je suppose-).
Et le panorama Navcam pour le contexte :
Je faisais remarquer sur UMSF la curieuse dichotomie entre les deux faces principales, l'une claire et l'autre sombre. Il est très probable que Marquette Island soit un éjecta d'un cratère situé un peu plus au Sud à quelques centaines de mètres, et qui semble être vraiment récent.
