Astuce pour raquette Intelliscope
thierry24
J'ai trouvé sur le net, une astuce qui permet aux propriétaires, comme moi, de la premiere version de la raquette Intelliscope, d'éviter que la raquette s'éteigne au bout de 15 minutes si on y touche pas.
Toutefois, ma traduction est faite avec le logiciel REVERSO, et ce n'est pas fiable du tout en matiere de texte technique.
Quelqu'un pourrait avoir la gentillesse de nous traduire le texte ci-dessous ?
Merci d'avance pour tous les usager d'Intelliscope qui sont dans mon cas.
One of the big annoyances with the object locator is the automatic power off if no button is pressed for 15 minutes.
Orion offers a chip replacement to change this to 50 minutes. Another way to deal with this is to make it easier to realign. Here's the trick:
With the object locator off, point the intelliscope accurately at a stationary object which you can point back at with high reliability. A distant radio tower lamp would be good. You could try the north star, but you will lose accuracy as the night progresses because the north star moves a little.
Now turn on the object locator in test mode by holding the enter button and pressing the power button. In the hidden menu, go into the alt az test mode.
Now set aside the locator, and align your program (such as ECUPro) as normal, and you are ready to go.
Now here is where the trick comes in. If the object locator powers off on you, you don't need to realign! Simply point the telescope accurately at the stationary object you chose before, and power the object locator into the test mode going into the alt az test mode and you are done. No need to realign the computer program. this can be extended if you do not move your intelliscope between observing sessions. Again use the stationary object when turning on your object locator, but this time when you start up your computer program you can just use the the 1 star alignment instead of a normal one.
If you are curious why this works, it is because the computer program does not use aligned coordinate data from the object locator, but instead just interprets the numbers as encoder readings.
When you align the object locator, it provides aligned coordinate data.
When you go into the alt az test mode, the object locator provides coordinate data with the 0 alt 0 az point being the location you powered it on at.
This way, when you repoint the scope before powering on again, you are setting the encoder data to be the same.
Avant d'allumer la raquette, pointez le plus précisément possible un objet stationnaire toujours visible. Une tour radio éloigné avec une lampe fera l'affaire. Vous pouvez tenter de prendre l'étoile polaire mais la précision sera moins bonne car elle bouge au cours de la nuit.
Maintenant, allumez votre raquette en gardant appuyé le bouton enter pour entrer en mode test. Dans ce menu caché, allez dans alt az test mode.
Maintenant, laissez la raquette de côté et alignez votre programme (comme ECUPro) normalement, et vous êtes prêt à y aller.
Et voici le truc:
Si la raquette s'éteint, vous n'aurez pas à réaligner !
Repointez l'objet stationnaire précédent, rallumez la raquette en mode test alt az (comme plus haut) et c'est fini. Pas besoin de réaligner le programme.
Vous pouvez également simplifier l'alignement si vous ne bougez pas votre téléscope d'une session d'observation à l'autre. Vous utilisez l'objet stationnaire comme précédement, mais cette fois vous pourrez utiliser l'alignement à une seule étoile.
Si vous vous demandez comment ça peut bien marcher, c'est parce que l'ordinateur n'utilise pas les coordonnées après alignement mais lit simplement la valeur retournée par les encodeurs.
Quant vous alignez la raquette, elle fournit les coordonnées dans le repère alligné.
Quant vous allez en mode test altaz, la raquette fournit les coordonnées en partant du pointage à l'allumage.
Ainsi, si vous pointez toujours le même point immobile à l'allumage, le bouzin reste dans le même repère.
Merci beaucoup LEIMURY,
Il est vrai que ta traduction est plus explicite que celle de mon traducteur,
Ah si j'avais été plus attentif en cours d'anglais.....
