Hello!
juste, avec quoi pourrais-je ouvrir "kernel32.dll" pour suivre ce tuto svp?
1) Download the source for wine
> 2) In wine-0.9.31/dlls/kernel32/kernel32.spec change the following two
> lines:
> @ stdcall FindActCtxSectionStringA(long ptr long str ptr)
> @ stdcall FindActCtxSectionStringW(long ptr long wstr ptr)
> to
> #@ stdcall FindActCtxSectionStringA(long ptr long str ptr)
> #@ stdcall FindActCtxSectionStringW(long ptr long wstr ptr)
> (i.e. comment them out)
> 3) Rebuild wine...
> a) ./configure
> B) make depend && make
> c) make install (must be root to do this)
> 4) Copy the following dlls from your windows:
> msvcp80.dll
> msvcr80.dll
> gdiplus.dll
> mfc80.dll
> to your system32 folder in your wine dir (normally /home/<your
> username here>/.wine/drive_c/windows/system32/
> 5) Download the DSS exe and extract it to a folder (maybe your home
> dir?) using the command unzip DeepSkyStacker_exe.zip
> 6) Next type winecfg. Under the applications tab click the add
> application button. Then navigate to DeepSkyStacker.exe and hit open.
> Select windows version: windows XP
> 7) Click the libraries tab. In the new override for library box enter
> the name of the four dll files you previously copied to your system32
> folder (one at a time!). Next (for each of them) highlight them, click
> edit and set the override to native.
> 8) This isn't always required, it is processor dependent. Add the
> following to your kernel line in your /etc/grub.conf file:
> noexec=off noexec32=off
> so you should have something that looks like:
> module /vmlinuz-2.6.19-1.2911.fc6xen ro root=/dev/md1 rhgb quiet
> 9) reboot
> 10) If all has gone well, in a terminal type wine DeepSkyStacker.exe.
> It should launch dss :)
> 11) If you turn beryl/compiz off you'll get a far smoother ride ;)
merci d'avance
José
non il est dans un dossier qui s'appelle kernel32 mais il n'est pas dans la dll de windows ....
il faut trouver où se cache le dossier wine-0.9.31 qui devrait lui même contenir un dossier "dlls" qui contient un dossier "kernel32" qui contient ton fichier kernel32.spec que tu dois modifier ....
:beer:
Hello!
en effet sauf que je ne l'ai pas :cry:
a mettre DSS sur mon 11.04 (oui je persiste)
astronomicalement
José
moi j'ai installé wine avec adept et ça marche pour iris , Nebulosity , pixinsight ....j'ai jamais rien eu à modifier .....
bon je ne connais pas DSS donc je n'ai pas essayer de l'installer ....
ton tuto dois dater car "wine-0.9.31" fait penser à une veille version 0.9-31 datant de 2007 ... ils en sont à la version 1.3....
tout cela explique que l'arborescence ne soit plus la même ....
Modifié par gglagreg
en effet, il me semblerait que ce soit le kernel32.dll (car dans le dossier dlls), comment pourrais-je donc l'éditer?
mettre à jour wine peut être? c'est bien la première fois que je vois quelqu'un vouloir modifier le noyau en binaire de wine...
je n'ai jamais eu à bricoler comme ça avec wine même des années en arrière.
j'ai déjà essayé mais ça ne tourne pas
c'est le tuto vers lequel m'a redirigé la personne qui s'occupe de DSS
apparemment tu dois partir du source de wine, modifier kernel32.spec que tu y trouveras, etc.
je ne sais pas si tu as déjà installé wine depuis le source?
en plus le tuto date pas mal pour parler de wine <1.0 ...
est ce que tu as essayé d'appliquer seulement les étapes 4 à 7 déjà pour voir?
