Hi,
This is the new structure self-built for my 16" Ostahowski mirror. Its very much light and portable that my previous Kriege-Berry classic design. I hope that like you.
Best regards.
Víctor
Woah, congratulations, it's very beautiful, it seems like a pro work !
Just a little thing that makes me feel dubitative: the secondary box isn't a little bit too high?
Becasue I think that you can earn a couple of grams by reduce it size, or, the better way, by making a single ring secondary box with a pyramidal secondary support.
sorry for my bad english
bye :)
José
Very simple, clean structure and a very fine finish and from this standpoint I'd say it is the same breed like the Krieg structure. Congratulation Víctor you did a great job ! :pou:
By the way do you find the central fan useful in the long run ?
... the secondary box isn't a little bit too high?
It's an f/5 dobson I think :)
Modifié par jgricourt
hello, very good job !!! it's a beautiful dobson. it must be easier to carry it now under the dark sky of spain... How lucky you are :)
Thank you all. The secondary cage is slightly oversized on purpose, it has a 450 mm of inside diameter for a 406 mm f5 primary mirror. I am not convinced ultra-compact designs in the style of Obsession UC telescopes, so I built a hybrid between the classic and the UC Dobson.
Yes, the central fan help, this run an only 800 rmp
Modifié par Acrab
A new telescope was born!He's very beautifull!It's the biggest telescope of the spain!
I'm sorry, i'm late!
Modifié par bubu bis
