I will try this...
Do you I have to make the changes in FlyCapture 2 every time I want to use the camera, or use firecapture, or are they saved?
Will I be able to use 2 camera, one with PHD and one to capture images without issues?
Thank you again,
Mark
P.S Sorry I cannot speak French!
I am using the camera for planetary imaging:
to this goal you should install
1)Flycapture 2 from the Point- Grey web page
2)Firecapture
3) connect the camera
4) open firecapture
5) open flycap2 and clik "configure selected"
6) in flycap2 go in the window "camera registers"
7) follow the instructions of message (that contain few words in french tapez =type appuyez=click):
http://www.webastro.net/forum/showpost.php?p=1533860&postcount=221
8) use Firecapture to capture the avi file
I am not using the camera for guiding
  • Réponses 299
Images postées dans ce sujet
Très bonnes nouvelles,
Edelmann, Torsten auteur du Firecapture a mis en œuvre un contrôle pour le trois registres dans la version beta de Firecapture.
En anglais:
Good news,
I contacted Edelmann, Torsten the author of Firecapture.
He reacted very rapidly in a very effective manner: he has implemented the modification of the 3 registers in the beta version build #37.
You can download the code here:
http://firecapture.wonderplanets.de/betas.html
A big thanks to Torsten for his code and his availability to our community!
To manipulate the 3 registers, there are new controls into the GUI under the additional controls (right-click or left-click on the gamma control to open the popup).
You should see:
1) "Gain2x". This controls the digital-gain. Namely which are the bits not considered in the 10bit to 8-bit conversion. The button puts F8 in the register 80 of the sensor. This corresponds to an increase x2 of the signal (independently of the actual value of the analog-gain).
2) "SignalBoost". This controls the reference potential of the AD converter. The button puts 00 in the 2C register of the sensor. This corresponds to an increase x1.2 of the signal (independently of the actual value of the analog-gain).
3) "GainBoost". This sets the analog-gain beyond the 12dB standard limit. It puts 7F in the 820 register of the camera. This corresponds to a 24dB gain level. For the moment the intermediate values of the analog-gain between 40 and 7F are not implemented. If you need these you should use Flycap2 as described above.
Notice that the off-state of this third button (of just this one) does not work, i.e. it does not restore back the standard level of the analog-gain. However, to restore the standard values, you have just to move the standard control of the gain.
I suggest you to always activate the "Gain2x" and "SignalBoost" buttons, and to play with the standard gain-control to cover 60-80% of the histogram. Just in the case that the maximum gain is not sufficient to cover the histogram, the third button "GainBoost" should be used.
On Jupiter (with average turbulence) at f/27 (with a Mak intes 703 + barlow, an Astrotech Voyager manual AZ mount, I have to manually follow the planet! No space for a bigger mount on my balcony) with very short exposition time, no IR filter, and the 3 new buttons activated:
FPS=61
Shutter=4.998ms
I have the following:
Histogramm(min)=0
Histogramm(max)=178
Histogramm=69%
Noise(avg.deviation)=27.09
Not bad (the histogram)!
Modifié par pippo
Has anyone got PHD working with the provided ASCOM driver in Windows x64. I've installed both FlyCapture x64 and x32, but when I try to connect in ASCOM diagnostics it simply reports:
Connect Failed...Could not load file or assembly 'FlyCapture2Managed_v100, Version=2.3.3.18, Culture=neutral, PublicKeyToken=76c6583b4a4585f4' or one of its dependencies. The system cannot find the file specified.
Can anyone connect to the camera correctly in x64?
Please note: PHD seems to work, but I cannot connect in ASCOM diagnostics and I cannot click 'properties' within PHD without an error.
Seems there is problems to get this 100 percent working?
Yes it works on x64. You must install Flycapture 32bits then copying the dll files in C:\Program Files (x86)\Point Grey Research\FlyCapture2\bin to PHD folder.
Reboot, and it should works ;)
Par contre j'ai un soucis, l'empilement des vues ne fait que "clignoter" sous PHD :( D'une vue à l'autre la luminosité change énormément (bien trop exposé la plupart du temps) et je suis obligé de passer trois plombes à modifier les paramètres du driver, c'est très pénible. Je suis le seul à avoir le problème ?
Hello Tromat,
I don't understand how copying the DLL files to the PHD folder would help with the ASCOM error. Could you try running ASCOM Diagnostics and then connecting to the camera and see if it works? Also, when you select the camera in PHD (The ASCOM box appears), can you select the options / properties, that is when mine gives the error....
Like I said, PHD seems to work even with the errors, but I don't think it is working correctly. Please try the above on your system and let me know.
Thank you, merci! :-)
Did you tried actually ?
It works fine for me :
Pour mon problème je viens de faire un petit test et il semble que c'est après avoir fait un dark que l'image devient toute blanche ou presque. Une idée ? Quelqu'un ? Siouplait...
Hi,
That is a different diagnostics.. That one works for me too.
The one I would like you to check can be seen at the top right of the ASCOM diagnostics screen, click 'choose device' then select camera, and then the PGR, then try and connect, does it work?
Mine gives the error I wrote above....
Mark
P.S I get the same problem using dark frames, it's because there is so much noise!
Modifié par markswift
Voici une image de Jupiter + Europe depuis Paris avec la Firefly.
Mak Intes 703 + barlow F/26.5 + filtre IR
manual alt-az mount
Turbulence 5 (fair) sur l’échelle de Pickering
http://www.damianpeach.com/pickering.htm
Paramétrés:
FPS=60
Shutter=16.15ms
Gain=935
Gain2x=0 (on)
SignalBoost=0 (on)
GainBoost=0 (off)
Brightness=140
Histogramm(min)=0
Histogramm(max)=139
Histogramm=54%
Noise(avg.deviation)=11.07
Modifié par pippo
Histoire d'ajouter mon caillou à l'édifice, un petit essai du 21 Janvier avec un capteur dégueulasse (on voit les tâches se balader sur le disque), une turbulence de fou et très probablement un tube à collimater. Mais bon c'était pour un simple essai de la bêta de Firecapture et ça marche très bien :)
Espionner les souris...c'est ne pas une surprise que ton capteur est dégueulasse maintenant! :)
Quel tube as tu utilisé?
Modifié par pippo
Huhuhu ^^ Deux choses ont changé depuis : le chat s'est occupé du problème de souris, et j'ai nettoyé mon capteur au coton-tige + alcool isopropylique.
Pour le tube c'est un Newton 200/1000 + Powermate 5x.
  • 3 semaines plus tard...
Voici une image du Jupiter + ombre Io + Io, du 18 Feb 2013 20:15 UT (21:15 Paris) avec mon Intes 703 f/26, suivi manuel avec alt-az, filtre IR et Firefly MV:
et ici une image du 15 Feb 2013 avec of Jupiter + Europe + ombre de Ganimede (et un peut plus de turbulence):
Modifié par pippo
Hier la turbulence a été minimale donc j'ai essayé de pousser la focale a f/35
Mak 7" intes 703 + Barlow televue 3x + Ircut + firefly MV + manual alt-az mount voyager.
Les paramètres firecapture:
Camera=Firefly MV FMVU-03MTM
Diameter=40.30"
Magnitude=-2.37
Date=190213
Start=205336
Mid=205450
End=205605
Duration=149s
FPS=61
Shutter=12.78ms
Gain=1204
FPS=3063 (off)
Gamma=0 (off)
Brightness=131
SignalBoost=0
Exposure=7
GainBoost=0 (off)
Gain2x=0
Histogramm(min)=0
Histogramm(max)=93
Histogramm=36%
Noise(avg.deviation)=15.25
L'image a la taille d'acquisition:
Image reduite de 80% pour comparer avec les images a f/26
Modifié par pippo
Pour ma part à f/25 sur un newton 200mm :
Elle marche très bien cette petite caméra. Franchement pour le prix je ne regrette absolument pas. J'autoguide sans trop de soucis avec et je peux faire un peu de planétaire, que demande le peuple :)
Bien que je ne comprenne pas un quart des details techniques que vous enumerez en plusieurs langues sur le fil (a quand la traduction en Castellan !) j'ai bien compris que cette cam etait plus interressante qu'une Spc900 longue pose apparement.
J'ai une Spc900 et je comptais la modifier (je comptais.. avant de voir la methode..)
bon, j'abandonne l'idee de la modification.
Me conseillez vous cette cam pour m'initier a la photo Longue pose ?
(sachant que si j'accroche bien et que j'investis dans un bon capteur, elle me serviras a autoguider)
merci, julien
Salut a tous !
Je pense que je vais me laisser tenter par cette petite caméra !
Par contre je voudrais savoir si vous avez tester avec un système de refroidissement ?
Je pense qu'avec un système arduino nano une sonde thermique et un Peltier il y a vraiment moyen de la refroidire efficacement. ! Et de contrôler le refroidissement avec un petit écran oeled.
Sinon super les photos de jupi je me demande se que sa vas donné avec mon mak 102 !
J'ai aussi vue qu'il y avais une autre prise sur la cam a votre avis peut on y avoir accès ?
Merci pour vos réponses !
pour 150 a 300E tu peux trouver en occaz des vraies petites CCD astro meade DSI pro avec jeu de filtres LRGB et logiciels. elles ne sont pas refroidies (faire une "cool box"?) mais sur le principe elles fonctionnent comme les "grandes".
si tu jettes l'éponge dans quelque temps tu ne devrais pas trop y perdre a la revente.
Salut à tous,
Pour ceux que ça intéresse, le logiciel Genika Astro publié par Airylab prend en charge les cameras PointGrey, enregistre en mode 12/16 bits et gère directement les fichiers SER : http://www.airylab.com/index.php?option=com_content&view=article&id=50&Itemid=75
Ce logiciel est livré gratuitement avec les caméras vendues par Airylab. En autonome, le cout de licence est de 70€.
Modifié par albanc
Salut à tous !
C'est bon j'ai sauté le pas, j'en ai commandé une ! :wub:
J'ai comme projet de la refroidir afin d'obtenir le moins de bruit possible.
J'ai vue que certain on essayé (résultat ?) et d'autre on y pensé !
Donc je me lance :
Montage dans l'ordre :
mousse isolante (avec un trou pour le capteur) > carte+ capteur > verni > colle thermique > plaque de cuivre > colle thermique au centre + mousse isolante > peltier > colle thermique > radiateur > ventilateur
Tout cela comprimé avec 4 vis.
Le système est isolé thermiquement sur les cotés jusqu'aux radiateurs.
Pour le montage électrique la je coince !
Voilà le Peltier choisi :
http://www.conrad.fr/ce/fr/product/193550/Element-Peltier-39W
Par contre je voudrai branché le peltier à un thermostat. Mais je ne sais pas lequel prendre.
Voilà ceux disponible chez Conrad :
http://www.conrad.fr/ce/fr/overview/2408005/Kits-rgulateurs-de-temprature
Je me demandai aussi avec quoi je pourrai alimenter ce petit monde ?
Modifié par dragonlost
J'ai pensé un peu à la même chose et je me pose un peu les mêmes questions. ;)
J'ai déjà récupéré un radiateur de carte mère qui a grillé.
Cependant, il me semble que la puissance du Peltier est trop forte. Les spécialistes en électronique confirmeront ou non...
Le Peltier envisagé fait 3.9W. ça parait un peu élevé mais pas trop si pas utilisé au max.
Ici une discussion avec un schéma fait par pam-pg (message 13). Il faut un peu l'adapter, mais le principe est bon:
http://www.webastro.net/forum/showthread.php?t=43709
Une référence de tension alimente d'un coté un pont de résistance avec un potentiomètre (réglage de la température à atteindre) et de l'autre une CTN (capteur de température). Les 2 signaux sont "comparés" dans l'ampli soustracteur, qui commande des transistors en darlingon qui eux même laissent passer plus ou moins de courant vers le peltier.
La grosse différence ici est que la tension du Peltier est beaucoup plus faible : 1.9V max.
Il faudra une alim de 4A, pas possible à partir de l'USB.
Si on veut alimenter le montage en monotension, pas trop élevée. Il faudrait utiliser un ampli mono tension rail-to-rail.
Ensuite pour la commande des peltier, le plus simple serait d'en mettre deux en série (ou un seul avec une tension double), pour augmenter la tension et alimenter le tout en 4V avec une alim de au moins 3.5A.
Peut être encore jouable avec une alim 3.3V (ça devrait suffire pour les pelletier), à vérifier avec un ampli basse tension.
La grosse difficulté sera d'éviter le givrage du capteur si il est laissé à l'air libre. Il faudrait le mettre dans une chambre fermée par un filtre par ex, et avec du dessicant dedans.
Modifié par olivdeso
Hello,
J'ai une petite question. (je précise je suis un gros débutant)
J'ai commandé la fameuse firefly et j'ai aussi acheté un adaptateur qui se visse à la place de l'objectif (l'adaptateur sort avec un diamètre de 3cm).
Ce soir je me lance et je bricole un adaptateur pour mettre le tout sur l’oculaire.
Mais voila premier test négatif, je ne vois rien. :cry:
Je réfléchis un peu, j'enlève mon adaptateur, je remet la lentille livré avec la webcam et en la collant sur mon oculaire je vois un point blanc (Jupiter).
Ca remet donc tout ce que je pensais avoir compris en doute.:b:
L'un de vous pourrait t'il me faire un schéma ou m'expliquer comment raccorder la webcam à l'oculaire?
Merci d'avance de votre bon cœur.
J'ai acheté la même webcam avec l'adaptateur, je n'ai pas pu encore l'essayer sur le ciel (pas beau temps).
J'ai monté l'adaptateur à la place de l'objectif et glissé l'ensemble dans le porte oculaire (sans oculaire) et j'ai fait un test en mode terrestre j'ai une image sur l'ordi en faisant varier la mise au point.
Au niveau grossissement j'ai du mal à me rendre compte de ce que cela donne.
Voili, voilà :)
Et voilà j'ai reçu ma caméra ! elle marche niquel et je suis impressionné par ces performance !
J'ai mis a jour le firmware et j'ai installer le dernier sdk. Par contre, fire capture ne marche pas chez moi il ne détecte pas la caméra.
Je me demandé, serait-il possible de contrôlé le port GPIO à partir du driver Ascom. En effet il serait assez simple de relier un port ST-4 au GPIO. Il faut juste relier les pin 2 à 6 du port ST-4 au pin 3 à 7 du port GPIO.
Après il faut paramétrer le pilote ascom pour qui relier la masse à une des pin en fonction de RA+, RA-, DEC+, DEC-
Je fait des supposition je ne sais pas du tout si c'est possible.
